engine swaps and problems
Victoria, Australia
I been looking through the forums here for info on a conversion of a 2f to a 3b but have not been able to find anything of value. Can anyone provide the thread that will answer my questions which are: what needs to be changed / added if i was to remove a 2f petrol and replace it with a 3b diesel such as engine mounts, bell housings, transmissions etc. Is there a thread that covers this info
Thanks
Engine Mounts, bellhousing, input shaft on tranny will all need to be changed. In my opinion better to get the correct tranny and bellhousing with the motor than try to change everything over. The changing of the input shaft is a real PITA unless you are tranny guy.
torskin,
go to the intl section and look at the swaps that have been done recently. lots of info...
mike
I have a transmission and tranfer case from a bj 60 that had a 4cyl diesel, the tranny is a 4spd and transfer case is a split style both in good shape also have the bellhousing
wanna buy it $100
there is a crossmember that was under the tranny not sure if that is on a bj 40??
