Cats usually go early due to fueling problems. So your rich/lean condition is probably your root cause with a potential cat issue as secondary.
Cats usually go early due to fueling problems. So your rich/lean condition is probably your root cause with a potential cat issue as secondary.[/QUOTE
given all the o2 sensors and the on board ECU, how does the LC run rich and not correct itself?
Ok, so I'll look into the o2 sensors. It sounds like that should help with the stalling and the gas mileage. Also, I get a ticking sound from the cats while I'm driving. I've always noticed this and it is unique to my LC. It sounds like drops of water on a hot surface that disintegrates the water immediately. Any thoughts?
I wasn't trying to say you have a bad O2 now, just answering your question of how the AFR could be off "with O2s and ECU". You'd have a CEL if they were bad. The ECU follows a pre-programmed map and uses the front O2 to make minor shifts to the map in real time based upon variances in the specific motor and conditions. The rear O2s primarily exist to 'tattle' on poor cat performance, but also provide secondary tuning input to the ECU.
Some here have noted that replacing O2 prior to CEL have had increased performance. Probably a sign of a lazy sensor that it still within tolerance. The 2UZ appears to be tunes for reliability and longevity vs power and efficiency. Makes sense when you consider it was designed to last 300k and feed on fuel from remote places. Hence, I guess, a wide tolerance band.
I'm also not necessarily saying that you have bad cats. You'd have a rear O2 code if the cats weren't doing their job. Again, just commenting on a common cause of cat failure. In my climate at least, I have not seen lack of driving as a contributor to cat failure. People I've know with dead cats have always been due to an ignored primary failure mode. I do think there is a fueling issue.
A weak fuel system often manifest itself when hot. Vapor lock?
Regarding the noise from the cats... Our exhaust will tick with temp change (warming up cooling down) but should not tick when running unless there is a crack. The water sound you mention is especially puzzling.
if the sound is from a cracked cat, I should be ok.What kind of gas were you using? 89 or higher octane?
Darn, I was hoping that the 100-series cats were indestructable, but it sounds like they are not.
I fear that the cats on my 1998 with 188k are clogged, and it is not worth the money for me to replace them with the OEM catalytic converters (~$1400 per side).
Does anybody have experience using flowmasters, or other less expensive catalytic converters on the 100 series?
Has anybody successfully run their 2UZ-FE long-term without catalytic converters?
They no longer do emissions inspections where I live, and my preference is to just get rid of the catalytic converters entirely. (Those evil molecular mothers have the potential to catch your rig on fire; ask me how I know.)
It seems like running the engine without the cats should work fine in theory, as long as you trick the post-cat O2 sensors into delivering a constant low-level signal to the ECU.
Any feedback or insight with regard to the feasibility of eliminating the catalytic converters from the 100-series 2UZ-FE will be appreciated.
I may have found the culprit. Yesterday I got an check engine light and I toook it to my mechanic today. He told me it was a left Bank of the catalytic converter, it's all clogged up. I took it to the dealership and they confirmed the same. Fortunately I still have four months on the warranty for the cats. Couple of last thoughts, I noticed pretty high heat coming from underneath the car at one point, I noticed a ticking sound from the cats, more so in recent times than before, and my gas mileage recently was 11 to 12 miles per gallon.
I will post another update after my cats are replaced.
What's the update?
Nothing really to speak of. I haven't Been on off roading trip yet. I have one coming up next weekend when I'm driving through the desert so I can update afterwards.
Good luck, I would not want to test it in the Mohave desert in the summer!! If it breaks down you can die.
I appreciate the concern. I've been out there number of times, and there is no other way to tested the cats then to drive through hot weather to see if it stalls or not. Twice that it happened before was in northern Nevada and enroute to Vegas. I will let you know how goes. I've on the trip many a times and two other trucks with us.
