I am looking at buying a stock 1994 FZJ80 with 165,000 miles. $4K
No rust, very straight body, paint is good...faded hood. Clean underneath.
Has working factory lockers. Leather on front (manual) seats has worn like most. Rear windows will not stay up...they drop down about 3 inches. Regulators ??
The BIG issue is that the #4 cyl. seems to not be firing well.
Engine skips and does not have power until about 3000 rpm, then it seems to smooth out a bit...but can still feel the miss/skip/.
The #4 plug is black with soot....not oil. The other plugs looked normal.
Dry Compression:
175
175
185
165
180
190
So the BAD plug was on the # 4 cyl with the lowest(165) reading. I did the compression test with a new $50 gauge from Advance. I did it with all plugs out. BTW the "dealer" had someone put new plugs, wires and cap on a few days ago....not OEM stuff. Bosch platinum plugs.
??? brand on the new wires and cap.
he said "they" had a tough time with the distributor and had to take it out several times to get it right......I wonder if they knew what they were doing ???
What would make the #4 cyl. not fire well when the others seem to be firing well.....even tho they are not OEM ??
Are these compression test #'s OK or tolerable ?? I know they are more than 14 apart as per FSM.....
Could it be a bad injector ?? I have done several searches on this forum and still do not know what to make of this situation.
Is $4k an OK price ??
Any feedback is greatly appreciated ASAP..... if possible !!!
Many thanks.......I sold my dodge diesel 4x4 and the F350 4x4 so I could pay off some bills and hopefully get an affordable locked 80 !!!!!!
Dry Compression:
175
175
185
165
180
190
(nasty $hit) in the attic while it is cooler up there...I have successfully procrastinated on it for years .... until now
