Engine Head Gasket Repair?
  • Thread starter Thread starter ALF CO
  • Start date Start date
ALF CO
Signs that the engine head gasket needs to be repaired?
Thanks for the help.
What symptoms are you experiencing that lead you to think that you have a head gasket issue?
The coolant may be leaking through the head gasket? It's not a lot, but the exhaust color looks white. The coolant needs to be topped-up every week. Also checked and there are no leaks from the radiator or hoses. Thanks.
If no external leaks I would do a leak down test on all cylinders, do it cold and do it hot/warm. Does it run rough on cold starts?
My 93 truck (3.0l) last year developed an HG leak while I was at work all of a sudden ran rough for a few minutes and cleared up after the leak down It's #5 cylinder.
