Engine gasket set for rebuild?
Denver, CO
Hey all. I'm trying to put together a parts list for rebuilding a 97 1FZ with a supercharger using Beno's long block pdf. I'm looking for a breakdown of what is included in 04111-66036 so I can grab everything except the OEM head gasket, since I want to use a cometic instead. Does anyone know where I can find that? I've come up empty when searching.
Just by a complete kit, and don't use the head gasket.
If you had to separately piece together everything that's in the kit, you're not going to save the cost of a cometic gasket.
More likely it will cost you more.
I'll take the headgasket off your hands...
I can order Japanese kit I believe it was corteco made in Japan, I bought it in the past was around $150. More than likely the same baskets and seals as that comes in a Toyota box. I wouldn't use the head gasket or the valve stem seals. The factory valve stem seals are not Viton and by the time 100,000 miles rolls around their hard as rock. I could find the rear main seal that was Teflon I would buy that one too.
