I've read other threads about emergency brake adjustments but none of them address my issue specifically. First, a quick history leading up to the problem. I was removing and replacing the cover over the transmission on my HJ47 to cut new holes because I had a 5-speed H55f tranny put in and it moved the transmission back. In the process of trying to get the old cover off, I had to wiggle in different positions the emergency brake unit (which sat behind the 4wd lever). At one point, I heard something release (kind of like a line with tension releasing). When I put everything back together, the emergency brake won't release. It will tighten up when I lift it fine, but when I go to release it, the brake starts to resist the movement to push the brake handle down and it goes partially back up skyward.
I'd like to know what I did to cause the problem and then, of course, what I need to do to get my troopy rolling down the street again. I looked underneath and saw the cable goes to a drum between the rear part of the tranny and the rear driveshaft. There are four bolts to it and there's a small "pin" on the top. Not sure what that does or if it's important. A
Any suggestions would be very appreciated. If someone responds, please pretend as if I basically don't know anything about emergency brakes, adjusting brakes, etc. (because that's pretty close to the truth). So if you assume things that you know well because you've done it a hundred times, you'll lose me.
Thanks!
Thanks!
