Electrical Setup 101 Assistance - Solar and Vehicle Dual Charging for LiFePo4 Power Station (1 Viewer)
HSTexan
Supporting Vendor
GOLD Star
DFW, TX
I have and will always maintain that electrical is my weakest point of vehicle setup. I've decided this winter I want to finally bite the bullet and get my electrical setup the way I want/need. I have a hard time justifying the weight of a full time dual battery setup, so the solution I'm currently using is a removable Bluetti 180T LiFePo4 1433Wh power station plugged into the DC socket on the vehicle and then removed at base camp and hooked up to a 200W solar panel. I would like to simplify this setup so that it can stay in the vehicle full time and charge off both solar and vehicle and additionally increase the wattage to speed up the charging process. As it stands right now it can only take in about 90W while driving through the DC socket and 160-170W max from the panel depending on sun. Given the size of the power station it can take a considerable time to get it topped back off and my last two trips have really pushed the limit and comfort of how close it got to draining completely and letting my fridge die. I'd like to maximize charging capability while minimizing fuss and making sure the starter battery is always protected from draining too low.
There are a couple of options I've considered:
Setup 1: Vehicle battery --> Bluetti Charger 1 (this is an alternator charger that takes excess power generated for charging purposes; up to 550W output) --> Bluetti Power Station
Additionally I'd have roof solar --> XT60 connector in vehicle
Setup 1 would let me swap back and forth between charging the power station from the car and solar, but would require me to manually switch the cable every time I go from parked to driving. I've also read that the Charger 1 has quite a bit of room for improvement as far as use and battery protection goes (timeout is 30 min after shutoff, requires manually turning on and off)
Setup 2 is an attempt to merge these so I don't need to swap cables:
Vehicle Battery & Roof Solar --> Redarc BCDC1225 --> Custom made XT60 with power lead from Redarc and ground to chassis (or run to back to vehicle battery/Redarc ground)
XT60 would just say in cargo area unplugged when not in use
Questions for setup:
1. Is there an XT60 switch that would allow me to toggle which input is active without needing to manually unplug and replug in a cable? This would be a simple solution for Setup 1 so it didn't require me to do anything with the cables, but rather toggle a switch when necessary.
2. Is it possible to do what I'm thinking of with splicing together an XT60 from the Redarc power lead and chassis ground or would that be ill advised?
3. Looks like the BCDC1225 tops out at 375W out; the powerstation can handle up to 500W in through the DC/XT60 connection. Could I get away with the BCDC1240 instead since it has a max output at 600W? That way the Redarc doesn't become the limiting factor and allows the power station to charge at max capability. Between 200-250W of solar plus charging from battery I feel like it would not be difficult to surpass the 375W cap
4. Is there an easier way to accomplish what I'd like that I haven't even thought about or know about?
So follow up to this; I emailed Redarc proposing what I had in mind and they believed given two independent management systems that the Redarc would not output as it wouldn't see a battery feed. It truly is meant to only connect to a dedicated two post battery, be it LiFePo4, lead acid, AGM, or lithium.
I then proposed the question to the Bluetti group on Facebook as well and someone forwarded essentially the exact product I was hoping existed. Another new solar/power startup that was created on Kickstarter called ETaker. They have a 1000W DC-DC charger that can pull up to 500W from the vehicle and 500W of solar. The beauty of they system is that it comes with the vehicle input cable with ring terminals on one end leading to an XT90 input on their charger box. The solar input is an XT60 (which I already have), and it comes with an output cable that is XT60 already--a perfectly ideal product that will require no splicing on my end. The downside is I'll now have to run two pairs of wires through the firewall grommets, but still much better than needing to manually swap cables out. Listed at $300 on their website, but $230 on their Amazon store--it's also about half the price of a BCDC. Put it on order and will be testing it out before running wires, just to make sure it works as expected, but seems to be the perfect solution.
Amazon Link
I went down a similar road with my Bluetti AC 200P last summer trying to figure out the best way to charge the bank on trips.
I have portable solar panels but find my style of camping isn't that great for solar charging. (Under Tree Canopy / Not usually staying in one place for long)
I wanted something that would charge relatively quickly while driving. So I just kept it simple and wired in a 120Volt AC inverter in the rear. I use the AC charging brick when I'm driving which pumps in 500watts. I don't think I would want to pull much more than 500 watts from the stock alternator.
It's a simple solution with the added benefit of having some AC outlets accessible in the rear (while car is running) with or without the battery bank.
Just my .02
I had two generations of Goal Zero And ultimately decided the occasional portability of them wasn’t worth trading off vehicle integration. For a permanent build like you truck, dedicated lithium is the only way to go IMO
Hopefully by now it's clear that off-grid camping is eminently do-able.
If you're considering portable solar panels I suggest you have a look at Merlin. The review linked below mentioned some things about Merlin's quality and performance that made me buy their XP-170. I'm happy to report I am very happy with the panels. They're extremely light, durable and uniquely actually deliver their stated wattage or darned close. They make all kinds of panels for permanent mount for vehicles.
I actually bought the panels from a company called 4thD Solar.
Interestingly, 4thD Solar is owned by the same guy that imports Kimberly Caravans to the US who I met at Overland East 2023 but I didn't know this when I bought the panels. It was when we were looking at travel trailers that I noticed all the Merlin portable panels. I talked to the owner for a long time regarding off grid implementations, solar panels, charging from the tow vehicle, the RV industry and other topics. I found him to be an extremely interesting and knowledgeable person. Kimberly also uses Merlin for their factory supplied solar panels on their caravans AFAIK.
I have no affiliation with either Merlin, 4thDSolar or KImberly nor do I receive anything for mentioning & plugging their products.
REF:
Solar panel test results
Portable Solar Panel Testing- Results - https://forum.expeditionportal.com/threads/portable-solar-panel-testing-results.200834/
4thDSolar
Real Solar Power! The best, most efficient and toughest solar panels - https://4thdsolar.com/
EDIT: link to Merlin Solar
Home | Merlin Solar - https://www.merlinsolar.com/
Kimberly Caravans booth with Merlin XP-170 Solar panels at Overland East 10/2023
Our Merlin XP-170 in heavy use at Oregon Inlet Campground 6/2024:
Lot of good info in here and appreciate the input-- @tbisaacs man I went back and forth so much on a permanent LiFePo4 battery in the cargo area, but I just don't think I have a great place to mount one permanently. The more I think about it the more I think I'll end up there one day, but for now this ETaker is going to get a chance. It should be here today for me to test out before permanently wiring it up. If it doesn't work like I hope I've already pulled my drawers out in prep to run wiring so it would be an easy pivot. Would just need to fab up some sort of battery tray--probably between drawers and backseat.
The ETaker is new to me and looks interesting. The wattage is pretty high. Is the input wattage selectable?
The block diagram below is what I've done so far to support camping in general. The refrigerator can run off either the Goal Zero or the Odyssey battery under the hood. The SB-175 is used to charge our trailer under tow.
It is 1000W combined split vetween 500W max from vehicle and 500W max through solar. That said it does have basic selectability to limit the pull from vehicle to either 300W, 400W, or 500W. My current plan is to pair it with a 300W solar panel and leave it set to the lowest setting of 300W. This should hopefully give me somewhere around 250W in (in ideal conditions) when the vehicle is powered off from solar alone and then hit the max of 500W combined when driving while also keeping the vehicle draw as low as possible.
500W/40A off your OEM alternator as input to your would be the most I would draw off the OEM alternator. Prior to my alternator upgrade I drew 40A to feed my Victron 12|24-15 which output 360+W-30A (15A @24V) to my Goal Zero 1500X. The point is, these chargers aren't 100% efficient so whatever the output, the input will be more. It's wise to measure it all with a power meter.
The OEM alternator is rated at 180A however, I really don't know if I was taxing my alternator or not as that 180A is the maximum at some unknown engine RPM. I didn't run it very long at that load, maybe a year and not continuously. My LC200 engine idles as low as 550RPM which at that rate, I am assuming, the alternator produces about 100A. In addition, the alternator cooling fan is not cooling as much. If the Amp guess at 550 RPM is close to true then drawing +40A to your charger is a lot. I haven't seen a RPM/Power curve for the OEM alternator. If anyone has one I'd love to see it as I think it would settle a lot of discussions.
Revisting this... I've been obsessing with my electrical setup to get both the organization and capacity for what I need.
Current setup:
E-taker F1000Pro Alternator/Solar- DC-DC Smart charger
Renogy 400w Bifacial Panel mounted to RTT
GoalZero 1500X
These supply the face mounted outlets:
-12V mounting block to supply two 12V USB round ports.
-Household plug extension with 2x110 and 1 each USB-A &C. https://www.amazon.com/dp/B0D3WDC1MC?ref=ppx_yo2ov_dt_b_fed_asin_title
I'm pretty happy with the charging rate now. I've limited the current to 300w alternator, and 400w solar. The Etaker did take a bit of fiddling in its app to get it dialed in correctly too. But now seems plenty fast to get the battery charged up. Sunny days are no problem if I watch where I park at a trailhead. We did a 4 night camp in the Whites with a fridge, induction top, 600w hot water pot, and miscellaneous USB camera, phone, etc. Everything went pretty well except the night she wanted to boil potatoes on the induction top. Drained 40% out of the yeti pretty quick. I could see a couple days of cloudy and parked could become an issue with the cooktop. Although eggs, meat and pancakes seem to be quick enough- Long boils are the issue. So thinking about a bit higher capacity battery.
Having everything- ,battery, inverter, BMS, 12v, inputs, outlets, USB smarts- in the GoalZero sure makes it easy, I just plug the 120v into it for the inverter, and fabbed a 12v anderson line to supply the round 12v ports I installed in the drawer wing face. I made a powerpole cable to supply the power from Etaker to the goal zero. I have the Goal zero facing front on the drawer side of my Trekboxx. I haven't bolted it down as well as I'd like quite yet, just a strap, enough while I figure it more permanent layout.
The Goal Zero (or a similar power station) sure simplify some of the electrical work to plug and play and also provide some ports mid ship in the second row- but they are not great for packaging & arrangement. Although the overall volume is nice and tight relatively, there's no chance to hide it in a wing or mount on the face of the drawers behind the 2nd row. It takes a modest chunk of space in the main cargo spot on the drawer deck and could be subject to things being piled behind, on, and around it.
I think with the Etaker I could go directly from Etaker to a LifePo battery like the new Renogy SuperSlim or this crazy deal one I've stumbled across this morning. 12V Lithium RV Battery - 3 kWh - BatteryEVO RAZORBACK - https://batteryevo.com/product/12v-razorback/. I'd need an inverter too, but that seems straightforward enough.
Any feedback welcome on some of these "unknown to me" battery brands. Or my setup thought in general. This Razorback battery may even fit in a wing of the Trekboxx. Trying to mount it behind the second row would require the seat slid all the way forward.
HS? Also curious - what's the latest with your setup?
Thanks in advance.
Somehow, I missed this thread as I built my system which is based on EcoFlow devices.
My setup is based on a Delta2 (1024wh), a Glacier fridge (with its own builtin 300 wh battery) , and a 300wh River plus EcoFlows alt charger. Currently I have no solar but will add that at some point.
Functionally, this all work’s pretty well. I generally drive enough each day to keep everything charged with the alt charger set at 300 w max. Sometimes I drop it to 200.
It’s all mounted on the fridge slide out (except the alt charger) with straps. I’ll eventually make some cleaner brackets but space wise, this works great. The straps have survived some fairly hard wheeling in Moab and in Ouray. The alt charger cable management system (bungee cord) looks a little cheesy but works. I also need to sort out what I want for cargo dividers. All a work in progress.
I tried my GoalZero on the slider both in front and back of the fridge at first. Workable and it was nice to have the GoalZero outlets right at the back, but if I had other stuff plugged in it became a bunch of cables moving back & forth or unplugging/plugging. Moving the power station to a fixed location allowed me to use a plastic cable drag chain/snake thing which works great to manage the fridge’s single cable. But…GZ now takes up cargo room elsewhere. I have my water jug behind (tailgate side) the fridge now.
I debated a long time on the EcoFlow stuff, looks quality and just works. I went cheaper in the end since I had the goal zero already. And now that I’m diving into it I feel like I can build it out just the way I want…with the right form factor battery.
Charger mounted same as yours. Solar on top coming from a XT90 port in d pillar near the factory inverter socket. The black 110v wire coming from the GZ to a 110/usb combo socket in the back wing face.
Plan to get a bit cleaner with my cables as I commit. Thinking this passenger side front face is where I might instead put a slim battery, but then I’d need an inverter in the wing I suppose.
Car 12v socket on the GZ to the fridge in the guide. Very happy with that.
Bit of spaghetti bowl here. 110v coming from the GZ, 12v as well, xt90 outlet supplied from the roof then runs to the Etaker charger. All shoved in the overstuffed cable conduit.
Outlets.
Yeah, I’m going to look at those drag chain things. I initially thought that having the battery on the slide out, was going to be a pain for the reason you described but so far it hasn’t really been a problem for me. Anything I plug in to the batteries are on the slide out. The only random things I ever charge while stationary With the delta two are my Apple Watch and headlamps or maybe radios. I just set them on the slide out or on top of the battery while I’m doing that so it’s not an issue. I’ve run a short AC extension cord with three outlets on the end from the battery to the front of the fridge that just sits on the slide out this lets me plug in my induction burner or any other random thing I need for cooking.
At some point I will want to wire at least some lighting or something else fixed to the aux batteries. My thought is just to mount a terminal strip somewhere and provide some AC in DC wires to that and put those wires in the drag chain or something.
Thanks in advance.
I unfortunately have gotten super occupied with other hobbies for the past 9 months so my electrical setup is all purchased, but still sitting in the garage waiting for me to put it in since last fall. The base of the system is like yours with the ETaker 1000 being able to both input solar and alternator excess into my Bluetti AC180T powerstation. The panel I bought that I will be using is the BougeRV 300W bifacial panel which is absolutely incredible. It overperformed in my own testing and was able to actually peak at 301W input to the Bluetti.
From there I'll be able to jump my fridge to the Bluetti which isn't the most efficient way to use power, but even when the fridge compressor is actively on and it's trying to charge the internal fridge battery it only pulls ~150W max so the panel should be enough to keep it relatively topped off if parked. Worst case scenario I can turn on the vehicle for 30 minutes and get some decent power from the alternator, but the internal battery is usually good for 48 hours in blazing heat and 72 if it's cooler outside so I have some decent wiggle room to account for rain or shade. The one thing I'm doing that is probaby a bit "extra" is that I'm putting Anderson connectors on the ends of all my cables to make it easy and clean to unplug everything if I want to pull it out. I really would like to at least get the panel mounted and wired before my mid-October trip, but the ETaker will require me to pull the drawers out so that will again wait until winter when things cool off here in Texas
How are you going to use the Bouge RV panel? Are you mounting it to your roof or will you deploy it on the ground somehow? I think that is a ridged panel?
Full rigid panel on the roof rack--flat mount for now, but I have been looking at some mounts that I could angle while stationary as well
