Hi
I am having an electrical gremlin that is starting to hack me off.
The symptoms are loss of electrical power after 15-20 minutes of running, the volt guage drops off and the vehicle will stall out at idle.
On the surface appears that the alternator isn't charging, however i have had an auto sparky go over it and he couldn't fault it (vehicle was only just warmed up) as the alternator was charging perfectly. however, after leaving the shop 20 minutes later the volt meter was dropping off and it wouldn't start when i stalled backing into my garage. It did start half an hour later.
has anybody had issues with alternators not charging when hot??
The engine is a GM V8 running a GM alternator (internal regulator)
Thanks
Tony
Thanks
Tony
