I needed power for the controller, and a brake control wire from the controller back to the trailer plug. I also needed power back to the plug to keep the trailer battery charged, and to power trailer accessories. The other two wires on my controller were ground and brake sensing. I wanted power to the back of my truck for accessories anyway, so I started with a 50 amp marine breaker from West Marine, attached at the battery. Big fuses are less versatile and more $ at stereo shops. From the breaker I ran 10 guage wire through a rubber plug in the firewall, where the clutch actuator would go if I had one. I terminated under the dash with a ring connector, where inline fuses run to a few new accessories including the brake controller. Another 10 guage wire runs from there to the jack stowage compartment. I used the ground under the center console, I prefer factory grounds. I tapped into the brake wire after the switch on the brake pedal for my brake sensor wire.
Running all the wires back is fairly easy. Under the door sills is a deep channel with some wiring already in it. I ran my 10, 12, and four smaller wires with room to spare. One of those wires is from my accessory power, it runs a relay to the trailer power so it's only connected to my battery when accessory power is on. The others are for accessories. I'm running a plug-n-play four-prong trailer light plug by Draw-Tite, and a seven-pin adaptor.
