Couple of issues with a line lock…
Firstly, you can only switch them on for around 30 seconds at a time. The solenoids get hot so have a short duty cycle.
Secondly, they require constant power when active, which is fine for a few minutes but no ideal for parking…
Third, if the motor gets hot and current increases and blows a fuse, suddenly they will release pressure and the vehicle will roll.
And finally, here in Australia the rules and regulations state the handbrake must be mechanically activated and not rely on hydraulic pressure (so that rules out using a hydraulic hand brake with catch).
I have done a previous 80 series handbrake using a Subaru caliper with the handbrake built into the caliper itself. It works really really well, but requires welding a new bump stop bracket to the axle to protect the handbrake cable (which is a bit of a pain).
So now that the electric handbrake calipers are coming down in price it seems like a good option… well, they have their draw backs but I still consider it better than the 80 series drum design.
This is great info, thank you for sharing.
1 , 2) i know that I can purchase solenoid valves that can be energized to "change state" but then not needing power afterward to maintain the state. Well, at least in the automation controls industry these types of SVs are avail, not sure in the 12vdc realm if such things exist.
alternative - how about a mech plunger instead of a SV? Granted, plumbing then becomes a nightmare if you have to bring it into the cab. Wonder if a remote cable operated plunger even exists
3) the mech parking brake is still being used, the line locks are for "special times", like whilst winching.
Again, good points and I learned something. Thx!!
