Tagged for later, thanks OP!
Here's the part I bought: Amazon.com: OKAY MOTOR Engine Coolant Temperature Sensor with Pigtail Connector for GM GMC Chevy Cadillac Buick Oldsmobile Acura Isuzu Honda: AutomotiveDo you happen to have the part number for that honda temp switch?
Looks awesome! I'm going to grab one of those hose couplers that's clean! How does the variable speed controller work? Do you have video of it on low and high speed? Thanks for sharing!J1000, thanks for all the information. I just replaced my original radiator with an all aluminum Amazon one and did the electrical fan conversion. The radiator is a little thicker, longer, but not as wide. I used Derale part #16838, flex-a-lite controller 33055, flex-a-lite 1/4 NPT thermocouple, Amazon alum hose coupler with sensor hole, generic SPDT switch (Amazon).
Hello from Norman, I added one myself, and it helped some, I recharged my LCs A/C as well and that helped the most. However I have discovered that my radiator is failing. I will be taking mine in to the dealer to check the system and have it cleaned as well. I suspect I may have other things going on. I should clarify, I haven't done this conversion yet, but I added the additional cooling fan to mine from the older model 100s. Looking at doing this conversion since my radiator is failing.Those that have done the electric conversion, still overall positive about the change?
Does anyone have it done that deals with 100+ degrees? I put in a toyota radiator last summer with new clutch and don't have any heating issues. But, my AC will get warmish after idling in 95 deg heat after about 10 minutes or so. I added the little AC fan and that helped, but it still doesn't stay cold. I'm wondering if full electric conversion might be better?
Hello, Reviving an old thread.
Someone told me that by converting the 2UZ-FE to an eclectic fan , it is possible to get +2 MPG increase in fuel mileage. I did some searching on here, and I didnt find any accounts of anyone doing this other than yours. Can you let us know if that is true, did you see an increase in fuel economy by doing this?
thanks
Do you have any photos of your setup? Thinking about doing this with my 04 LX.Hmm I forgot about this thread until you bumped it.
I never did see any noticeable change in MPG when doing the electric fan conversion. However, I didn't track my mileage too closely (awful + 2 is still pretty awful) and how I use my 100 means I rarely have a tank that breaks 10mpg anyway.
I ran with the electric fans for around 2 years, but I have since had to go to a combination mechanical/electric fan solution because I was unable to keep my LX cool under certain conditions. Namely:
My solution to these issues was to run two electric fans (pusher/condensor fan and one puller in the engine bay) plus the mechanical fan. The e-fans keep the engine cool on hot days/low range and the mechanical fan moves enough air when towing my camper to allow me to climb the crazy grades we have around here without stopping.
- Going over colorado mountain passes in summer - even when just moving itself, this requires a lot of power/RPMs and I would watch the coolant temp climb to 230+ before I'd let off the gas and drop down to 55mph or so to let the engine cool
- Towing heavy loads on any sort of grade (camper is 6500lbs but even my 2500 lbs trailer causes issues) - I have the 10% underdrive gears in my T-case, and the electric fans cannot keep the engine cool when towing up any significant grade here in colorado. Winter, I can maintain about 35mph over most mountain passes. Summer - no chance at all. I had to stop probably 5 times in 10 miles heading from 5500 to 8500 feet due to coolant temps reading 240+
Got a few. I chopped up the derale shroud I bought (took about an inch off the depth and expanded one of the fan holes to allow more airflow and stuck a pusher fan in the shroud through the other hole:Do you have any photos of your setup? Thinking about doing this with my 04 LX.
