The issue is, while 7psi may be the sweet spot for that SC, as you've noted, larger turbos are not really all that efficient at these lower pressure ratios. So, to limit the turbo to the optimal supercharger pressure ratio in your comparo's, you're artificially limiting the turbo application's performance in order to suit your argument.
Now, I do agree that you obviously have to mind your dynamic compression ratios, but without research, no one can really say how much boost you can safely run on a properly tuned 1FZ-FE. Your only REAL concern is detonation.
I regularly ran 22psi on a T04R turbo in my 3L I6 that had an 8:1 compression ratio on 93 octane in the middle of summer in TX, with no detonation. I'm sure that with your experience, you've had your assumptions blown out of the water before.
I'm not advocating trying to run that much boost on a 1FZ, but I don't think we should be making any assumptions here without the appropriate data, and I definately don't think that we have a very fair comparison here.
My real concern isn't detonation, my real concern is a bolt on turbo to a N/A application running more than 8psi. How do you know you had no detonation? You didn't hear it? By the time you hear detonation, the damage has been done, btdt. I'm not at all blown out of the water, I just don't have enough information on your setup.
What did you run for fuel mods, timing, intercooler exhaust and ecu? Airflow meter, chip tuning, data logging? Is this the 3LI6 in your Toyota Supra that is 'down'. That's a turbo motor already (and I'll pass on the obvious question
.... I visited Sound Performance here in Chicagoland, they are getting 550-880 dyno horsepower out of that motor. Different egg, unless you are speaking to some other I6?
I regularly run turbo 2.2L motors to 26psi on 93 octane at 9.3:1 compression ratios. 1 with 200k on it. That's also with no external boost control, it's all within the modified factory turbo ECU with a pressure transducer. I see nowhere any information that the ECU code has even been cracked in stock form on the 80. Even if you did crack the code, it has no provision for recognizing boost.
The 1FZFE has cast internals not forged, which means, tho possible, I sure wouldn't be looking to push it very hard. Read Dusty's comments on the boys from the mid east and their experiences with high boost.
I've never blown up a motor (yet). That requires a very in depth theory and application background is required. It also gives a very good baseline for evaluating just about any setup. I see a stout motor here, but I don't see a big boost motor with bolt on mods here. We can't even keep the headgasket to stay put with the stock engine.
I'm more than willing to compare 7-8psi levels of boost, since that's really what we are talking. Christo, Dusty, Safari and AVO can take on the higher boost levels. Given what I know about this motor, that's not without risk, one I'll take a pass on thanks. Again, all my posts change if we start seeing 14psi numbers being posted from turbo apps.
That's not what I see yet. I won't even challenge that anyone do that, I'm happy to just give the argument assuming they did.
SJ
