Eaton E-Lockers vs. ARB Lockers (5 Viewers)
Mago: My experience in sand is that Crawl is perhaps the most useful aid when you are stuck. Lockers can tend to be of little use once you are bogged down but I have found that center diff-lock and to a lesser extent rear diff-locks can be useful in maintaining that all important momentum. In my opinion Front lockers are a bit of a liability in deep sand and cause you to dig in - especially when trying to turn.
Atrac is no great vitue in itself however and can in fact be a huge liability in sand. In sand you want to maintain wheel speed and momentum. If you understand what Atrac does to an open diff you will understand that the net effect is reduced potential power to a wheel with traction. See my Diff 101 comment somewhere above.
Ask any FJ Crusier owner what the that means in sand. FJs cannot disengage Atrac in low range (LC200s can disengage Atrac and VSC low range in both high and low range) When moving in deep sand often one wheel can suddenly start spinning at a different speed to the other even though both still have some traction. The Atrac system detects this and brakes the faster wheel resulting in a loss of all important momentum. and power. Try it with Atrac and VSC off and just your centre diff locked. Thats the best combination for deep sand driving IMO. Then try it with Atrac and VSC on. I bet you will be surprised at the difference.
I note there is much discussion on the FJ Crusier forum about an electrical hack that some bright spark has come oup with that stops the Atrac from re-engaging at speed or in low range. We are so lucky we can disengage Atrac at will.
r3run33: Yes, diff lockers when locked will interfere with the operation of Atrac and Crawl. But that's the point. When you want your diffs locked you do not want Atrac to function. Atrac only works if it detects differences in wheel speed between wheels on the same axle. Lockers engaged means there can be no difference. Its one or the other but not both. Atrac and Crawl still function with your center diff-locker locked however.
Brian: Yes I would totally agree. Factory lockers would be the ultimate solution. I only wish they would include them as a standard feature like they do with Mercedes G-Wagons and on new 79 series Landcruisers - which also come with Atrac and VSC. (Something Gaijin might like to consider.)
.... (LC200s can disengage Atrac and VSC low range in both high and low range) ....
Because someone else may also appreciate the answer, I'm going to ask a possibly obvious question. Where is the button or control to turn OFF Altrac and VSC?
My Land Rover LR3 does this crazy wheel braking for traction control so I know exactly what it's like to loose the power or momentum at an undesirable time! It is however still better at staying unstuck than in my stock 1996 Discovery which will just sit there letting a non-tractioned wheel spin away all day long while two other wheels on opposite site are sitting firmly doing nothing.
I have no interest in playing the E-locker fan boy but I will say that over the last few years I have given my E-lockers a full-on hammering without incident. And V8 twin turbo diesel LCs are heavy powerful brutes that must surely put enormous strain on the drive train all the way to the wheels.
I doubt there is anything inferior about the new LC four-pinion Harrop Eaton E-Lockers. I have not seen any reports of failures suggesting the contrary unlike the multitude of failures one sees with ARB and TJM airlockers (although most are not structural fails)
So JD's assertions above about their relative weakness surprises me. Being a reseller of diffs one would think he would know and I would tend to defer to his opinion, if indeed it is based on fact. Have you tested them JD?
Previous failures of the many variants of E-Lockers do not in themselves indicate the Harrop Eatons 4 pinion E-lockers are inferior. The only thing that will determine that is time but after 4 years I think a we would have had some indication as to there robustness.
I'll soon be re-gearing to one of JD's Nitro 4.8 ring and pinion front and rear sets so when the diffs are open I'll be sure to inspect for any evidence of unusual wear and tear and report back.
Here is an interesting and fully impartial review testing to destruction the various diffs available.
http://www.4wdaction.com.au/articles/2011/absolute-traction
It makes interesting reading. I note the E-lockers are strongest of those tested with a breaking point of 6926 lbs compared with ARBs at 6784 lbs force. They also mention the finish. I recall my installers commenting on the incredible degree of finish with the lockers - not that finish is as important as function but I understand all the E-Locker components are US fabricated and Australian assembled.
Question: Why are Eaton Harrop E-lockers not available in the US? Cant they be assembled, packaged and distributed at home? Somebody should jump on that opportunity.
Since the Toyota units are not actually offered by Eaton, only licensed by Eaton and offered by Harrop in OZ, we have no comparison. That said we have been a direct dealer of Eaton, ARB, TJM, Auburn, Powertrax, etc for years. We install all of them on a regular basis. We have had more failures of Eaton Elockers even though we install far fewer of them. So for demanding offroad applications we typically go with ARB, while more possibility of leaking, etc due to their complexity, etc, we have never had an ARB fail (as in break) in a diff that we have setup. Again, this is all based on US applications, we have NO experience with the Harrop units, but have heard good things. The GM8.5 ford 8.8, dana 44, and Dana 60 Eaton Lockers were the ones that had their fair share of issues. Since then Eaton has been redesigning the locking components as well as upgrading to 4 pinion designs when permitting. So for reliability in terms of electrical/ pneumatic components, the Eaton has the edge. For proven strength, range of applications, customer service, warranty, ARB has the edge. TJM while less engaged in the US market has a very nice locker, which is a good middle ground, less complex actuation, is less leak prone, better price, strong, but fewer applications. We have already looked into bringing these into the US, but it is not feasible with Exchange rates and with the odd scenario with how they are distributed. By the time they were stateside they'd be $2k each. Eaton's aftermarket torque control division is a very small portion of its overall size, and as many large companies, they cannot respond as quickly to consumer demand or "percieved" consumer demand. I hate to be a negative-nancy, but there are already good options available. Pltus its a bit of a Grass-is-greener scenario. Sort of like how we complain about FJ Cruisers and want "real" landcruiser 70 series, and then in the countries that get them, they have the opposite opinion:)
Billfish where did you ge those locker switches from?
Are you still happy you installed the E-Lockers?
Rgs
Scalci
Second thought about this thread...
I was following this thread and read the comparison at link above because I want to fit Diff lock to my LC100 2006 4.2 diesel that came with no lockers
I was missing more basic information like -
1. ABS, VSC etc. will work with automatic diff locker or they interfere one another?
2. If they interfere then selectable diff lock will be the only option or limited slip can work some how?
3. Limited slip should ok but for some reason I know that 100 series with Diesel engines dose not have limited slip diff at all - they have either selectable diff lock (electric) or non
Is there a reason for that?
Correct me if I am wrong here
4. I saw one diff lock model which is limited slip type with selectable option for full lock - electric
Look like the game changer or I am missing something?
5. Having so many options for diff lock would you mix and use for example selectable at the rear and limited slip front or other way around?
And last - if there is no interference between safety systems and automatic lockers like Detroit then why not using them ?
I know these systems will work whenever needed regardless what we want or think that needs but can someone describe a situation that I would regret having an automatic diff lock?
Just for the record - my LC100 dose not have diff lock but previous 4x4 I had has always rear diff lock so I really need to settle this issue...
Appreciate your comments
Actually, the elockers are now available in the USofA. See: https://forum.ih8mud.com/threads/new-kids-on-the-block-can-am-cruisers.844664/
Pricing seems to be reasonable ....
Hi guys - to confirm / comment on what has been said:
1. Harrop ELockers are available in North America via Can-Am Cruisers, described in the thread above.
2. We also offer installation kits, repair kits and suspension kits for all Series, including 200s.
3. A Harrop locker uses Eaton gears and is licensed from Eaton, but the diffs are made in Australia.
4. I am not a technician (that is Georg's job as my partner, while holding down a full time job running Valley Hybrids), so I am not qualified to speak to the issues of high/low pinions, CV damage, traction control, etc. - we sell parts, we don't give advice or install those parts.
5. We are an importer and wholesale supplier of Terrain Tamer/Harrop - see the thread for why we started this business and selected those vendors to represent. We do not sell ARB, Detroit, Chinese, Indian, etc. stuff and we are not objective as to the features and benefits of other solutions at any price point or level of (assumed) quality or functionality. We do not talk about other suppliers or comment upon the attributes of their wares.
6. As noted in our vendor thread, we sell wholesale to shops and resellers but will happily work with retail purchasers to get what they need and get it installed by a shop that will do the work properly. A call, PM or email is a great first step.
As for switches, we stock the OEM rotary locker switch as below, but suggest addition of an indicator light or tone generator if the operator has memory issues. :)
Can-Am is a small business supported by Australia's leading aftermarket supplier of OEM quality parts and accessories - 40,000 items supporting 3,500 repair shops and resellers around the world - from twelve warehouses. No brag, just fact.
Thank you for the opportunity to support the community.
Who was that masked man? :clap:
Thanks, Kemosabe
Georg is the Lone Ranger, I am Tonto - the loyal sidekick.
For a video on the Harrops, check this out....
Georg is good people.
I have been looking at the Eaton lockers for a while. After reading this thread, I am more eager to get them. Does anyone know what the instalation intail of?
HARROP EATON ELOCKERS & RESELLERS HERE
INSTALLERS AND INSTRUCTIONS HERE
QUESTIONS, ANSWERS & SUPPORT HERE
PS @Scalci - we love 'em and sell 'em because we love 'em. Feel free to email me for any questions about install or use. No installers in SA, tho :)
