Hey fellas,
Figured I would document this to help out some other noobies. Last night I was rebuilding my front axle for the first time, and accidentally drove both trunnion bearing races in upside down. Doh! I even tried to picture the bearings going in the race in my head but had a case of dyslexia and they ended up upside down anyways.
The problem when putting the races in upside down is that the wider end of the race now sits totally flush with the notches in the knuckle that are used to pound out the races when replacing them. It's almost impossible to get anything in the notch to catch the edge of the race. I could get a flat screwdriver to barely catch but it would slip with the tiniest bit of force. You also can't really get a socket in there to pound it out because the knuckle opening on the inside is smaller than the narrow end of the race.
I searched on mud for a while, and found other people had success with a 30mm socket, chisels, propane torches (to heat the knuckle ball), dremels, etc. Well the chisel wasn't working for me. And I could not figure out how to get the socket to work since the knuckle side is too narrow.
What worked: I found that the open end of a 21mm wrench fit through the notches in the knuckle (used to pound out the old races) but was wide enough to stop in the race. Just pound on the closed end of the wrench to get them out! Now unfortunately during my efforts I found that my Klein screwdriver tips are a stronger material than the race, so I'll need new races.
Hope this helps someone else who might make the same mistake!
