Early wiper motor
Blackcat37
Auburn Ca
So I am trying to rebuild my wiper motor and am wondering what others have used to replace the rubber rectangle piece? There also another small rubber spacer I need to find also.
Hopefully the rubber rectangle piece will be available sometime soonish. Someone on Mud is working on it. I haven't found a replacement for the rubber spacer, maybe someone here has.
I have had good luck using a hood prop rod grommet from a later 70's Cruiser which works beautifully in conjunction with the OE washer over it.
I believe @andybudge was reproducing them last year.
As for that other rubber piece,
They are used on other universal wiper motors like:
The other wiper motors are reversed polarity than the Toyota motors so you can't just swap them over...
Does anyone have any recommendations on who does rebuilds? I have several motors that need to be rebuilt.
Thank you in advance!
Thanks everyone I reached out to Andybudge to see if he is still making them since its a old thread. If not I will try and find something I can make work.
So I talked to Andybudge and he doesn’t have them made yet so I have been playing around with it. Here is the first test but with regular resin on the 3D printer. My buddy is printing it and it needs a few things fixed on it. Just ordered some flexible resin to see how that turns out. I will be able to put the lettering on the terminals holes like the original.
I am waiting on the flexible resin to see how that turns but I modified it some. For some reason it won’t print the S very good.
