Early 90 HDJ81 Brake Booster
Seikin were an oem manufacturer that might still produce them.
You should be able to substitute with a booster from any of the later 80series or 105series. Just check the bolt patterns are the same on the master cylinder side
Also, try @cruiseroutfit or their store at Cruiserteq.com
Seiken is not OEM.
Aisin/ADVICS or Bosch Braking Systems were OEM for service part support, generally depending on contractual agreements for monthly supply.
Seiken is aftermarket that reboxes other suppliers parts; They act as a front for OEM supplier companies that do not generally sell direct-to-consumer within the authorized Toyota dealership system for service parts support.
They also buy excess manufacturing parts and rebadge and sell under their own name.
@clay763 if you haven't figured this out, I just replaced my brake booster with an upgraded (2x the boost) booster from Performance Diesel Intercooler (PDI) in Australia. PDI 80 Series Dual Diaphragm Brake Booster - https://www.performancedieselintercoolers.com.au/products/pdi-dual-diaphragm-brake-booster-landcruiser-80-series I also installed a new OEM master cylinder and the difference is amazing. I ordered the booster along with their intercooler kit and a Gturbo all at once, the prices are in Australian dollars which are converted to USD once you pay (much less).
Cheers!
