Dual Thermostats? Problems with my hose
Truckee, CA
Having a strange problem that I have not encountered; and this being one of the few cruiser bb with some diesel experts....
I have a 1985 FJ60 with a Cummins 6A3.4t. I am running a stock radiator, cleaned out, new Napa-brand 13 lb cap. The engine has dual thermostats, relatively new.
The problem is the lower radiator hose keeps trying to blow off. No matter how tight I make the clamp. I assumed it was because the lower outlet of the radiator didn't have a "lip" on it. I had a shop put one on, and that solved the problem for a while. Then it did it again. I've never dealt with a dual thermostat system... seems overly complicated to me. Could a bad thermostat cause a hose to blow off?! What about a bad radiator cap? I would think that if the headgasket was blown (unlikely, it has not been overheated; no oil in the water, no water in the oil), it would first blow the cap (13 lbs)... but I'm not getting a large amount of fluid in the overfill. Maybe the new cap (again, Napa brand) is bad?
OK... update. I am begining to suspect that the 15 lb radiator cap is too much. Stock is... 9? Opinions?
yeah stock is .9 bar, which is I think 13lbs
Thats right 1 bar=1 atmoshere= 14.7 psi. I doubt an extra pound is what the problem is. You have a stock rad with a whole different system. You need the rad and cap for that motor; they design them that way for just such a reason. That engine likley requires a rad that has more capacity to cool and to take whatever that water pump is throwing at it.
.02
Good luck
