is this possible and if not, why not ?
If it is then why have i never seen anyone do it ?
So many questions.
So many questions.
I have two batteries in the rear for my stereo. I doubt that is what you are asking for but, it might help you.
Sure it's possible. Why do you want to do it? A lot more work than putting a dual battery in the engine bay.
my experience working with large inverters to power power tools and such is that inverters that are connected directly to a battery work much better than one that is attached through a cigarette lighter style power outlet - particularly ones in the back of a vehicle. What this told me is that the wiring between those power outlets in the back of the vehcle are not wired with heavy enough wires to support a load that big, thus I would like to wire a batter in the back of the vehicle with large guage wiring and then attach a large inverter directly to that battery.
Hiding all of this somehow is step two but, if assumptions above are correct, how this all looks is definitely secondary to powering a large inverter in the back of the truck. I could even remove battery number two except for times when i need it
It would still be easier to run large wire to the back than to put the battery back there.
What are you trying to do off an inverter that requires that much power? Remember they are very inefficient.
2400w, 20 speakers & 7.1 surround sound & can still seat 8.
I will post some better pictures whenever I get a chance to take them. These were taken during the build.
Either way you're running a large (at least 2ga?) run to the back either for the charging circuit for the battery, or for the inverter. You lose a lot of power to resistance (big delta V) with smaller cables.
There are plenty of off-the-shelf options for under the hood mounting of extra batteries and you should consider that in an accident/roll over a cabin-mounted battery can become a projectile. Good reasons for putting in the back though are less heat/cold (which batteries hate), better weight distribution, proximity to power distribution etc.
I went with a 0 gauge hot lead to a distribution block and a 2500W inverter behind the second row with a 100A SS circuit breaker under the hood. A short in that lead will burn your truck up pretty quickly. The Zantrex inverter has a remote 120V option, so I wired an AC GFCI outlet back to the rear hatch. I run electric hedge clippers up and down a 1/3 mile driveway, chop saw, Sawzall, electric impact wrench, pretty much anything I want with the exception of AC powered electronics. It's not a pure sine wave inverter.
Easiest way to run a cable that large is along the inside of a frame rail and come up through one of the drain plugs in the back. You can easily adapt a Blue Sea bulkhead wire fitting with large fender washers and RTV sealant.
I upgraded the alternator to a 260a & the batteries are wired in series to a Group 27 battery under the hood.
You could put a battery isolator if you wanted to run them separately.
so, to be clear, you have 4 batteries in total ? 2 under hood and 2 in back ... ? what does adding a 'group 27' battery to this mix accomplish ?
curious.
