More dual battery questions...
It is recommended (the safe and proper plan) that a suitably sized circuit breaker or fuse be placed as close as possible to EVERY 12v source (batteries and alternator). The goal is to protect against against a cable getting cut/chafed and shorting to ground. I can see this as important in my planned set-up where I'll have the 2nd battery on the opposite side of the engine from the 1st - that's a long wire with plenty of opportunity to get damaged, especially in a front end crash. The other wires: alt to isolator to switch to 1st battery are all going to be short with much less opportunity for a problem.
First I am now considering finding a way to mount both batteries on the (USA) passenger side of the engine compartment.
Second, and my real question here: does anyone have experience with a dual battery circuit breaker/fuse install partcularly in a system with a higher amp alternator (144) and a high amp draw winch (M12k Warn). I need a source to purchase and info on the install.
i want to do this right but I don't want to go crazy - even though I tend to be a belt and suspenders kinda guy.
Thanks,
mark
Thanks,
mark
