I've got about a 2" lift, Treaty Oak KDSS rear spacers, DrKDSS BOTCK, and DrKDSS Bushing Bracket. The KDSS rear spacers gave more room for the spare tire, which in my case is a 265/70/17. Previously, it was tight fit especially with the factory hitch. BOTCK helped bring down the track bar and thus pull the passenger side rear wheel back in. The bushing brackets helped to reduce the strain on the bushings. Honestly, I couldn't tell too much of a difference in driving, but I could see how the different kits helped correct the geometry.
I've posted about this before. I would avoid using front KDSS spacer. I originally had one installed with the lift to preempt any lean, but it extended the KDSS piston and caused it to contact the backside of the CBI skid plate. I talked to Dom and he said he no longer recommends the front KDSS spacer as it can over-extend the KDSS piston. That front spacer also didn't help with lean. I've got a slight lean (never more than 2cm) that comes and goes. Dom said cycling KDSS on/off with his KDSS harness kit can help fix the lean, but I've yet to get it.
Everything was pretty easy to install, but I remember having to do some heavy grinding away of an ABS tab for the BOTCK and it required a high level of care to not nick the ABS wire. I also got the billet clamps, but my factory straps seem fine for now so I haven't installed them.
