If an 80 series with a slee 6" lift had double cardan drive shafts on both the front and rear, and then the rig was lowered to a 2" lift, would it be okay to keep the double cardan shafts?
Thanks
Thanks
Thanks
You're going to be changing a lot of geometry if the 6" was setup correctly. Rear uca and lca will also need to be adjusted for your new height. Was your front caster corrected with plates/bushings /new arms?If an 80 series with a slee 6" lift had double cardan drive shafts on both the front and rear, and then the rig was lowered to a 2" lift, would it be okay to keep the double cardan shafts?
Thanks
Does anyone know if the driveshafts off a 91 will fit a 97?
It depends on the transfer case you have. 91-92 stock transfer cases do not have a viscous coupler. 93-97 do have a viscous coupler.
(93-97) Transfer case (with viscous coupler) requires a shorter rear drive shaft.
(91-92) Transfer case (without viscous) coupler uses a longer rear drive shaft.
91-92 transfer case is more desirable for big suspension lifts. Arguably a stronger design and longer driveshaft = more optimal U joint angles.
I provide this detail as its not uncommon to see transfer cases swapped between years, as FJ80 and FZJ80 transfer cases are interchangeable as long as you use the appropriate rear driveshaft length.
