I'm experiencing some version of this issue, driver's door only. And I've also noticed it only happens when the outside temp is around or about 70F.
Quite simply - as I'm walking away from the rig and hit lock on the remote, driver door half locks, all other doors lock, and then about 5 seconds later everything unlocks.
I've watched this closely from inside the rig as well, and the driver's side lock by the door handle that you could manually push doesn't 'throw' all the way, it makes it about 50% and then everything unlocks.
Again, only above 70 degrees F and only the driver's side. So its been business as usual all winter but I'm running into the issue again with the weather warming up. Sounds like an actuator motor burned out @archerwolf ? And what is the correlation between outdoor temperature and this issue?
