Hey guys
In the process of rebuilding door panels, and ran into a couple of issues.
One is the cardboard backing - the slots where the door clips / trim retainer clips sit are pretty chewed up in some places. Is there anything that can be done to make them sturdier and retail the clip properly? Example of the carnage below:
The other question is about the plastic moisture barrier. I was able to use the sticky adhesive and the OEM barriers to reattach. However, there is a loose flap at the bottom of the plastic moisture barrier that is supposed to cover the opening where the wiring harness comes out. Not quite sure what to do with this piece - is it supposed to stay loose as pictured? I was able to run a bead of the sticky adhesive right above the opening where the harness comes out, but seems kind of odd that the flap would just stay loose like that. Feels kind of unfinished to leave it loose like that, but I can't find any clear photos that show how it's attached from the factory. Any tips or ideas?
Thanks in advance for the help!
