Door panel hold down fix
DC
Website
www.instagram.com
Has anyone made or found a solution for the disintegrating places in the door panel meant to hold the plastic clips? I've got several places where I can't get my panels to stick down because the panel won't hold the clips.
Some folks have glued the clips in place in the panel, others have made new panels using the old as a template. Just depends on how much time you want to put into it. A little construction adhesive and the clips won't come out again. I use liquid nails fuse it. Even used it to repair my fender flares.
Fender washer and Dremel the center ID to a square to match the clip. Glue in place. On my LX it isn't needed but for other trucks where the fiber board is starting to disintegrate, it seems to work ok.
