Hi all!
Finally an HJ61 owner!!
My first LC is giving me some challenges already. Trying to restore some elec "shortcuts" previous owner(s) invented.
1. Central Door lock sw unlock = Lights up the instrument panel (like IGN) even in ignition OFF. Everything looks ok in the doorside with the connections. Just follow the Door Lock sw cable and find the hotwire connection?
Solved: 1 of the aft Door Control Relay short. Cleaned and working
2. Cigarette lighter has power all the time. Hotwired. Maybe associated to 1?
Solved: It's hotwired to battery and should work with IGN OFF
3. Aft Window wiper is always on when connected and ignition in ACC. Even when panel switch is disconnected. Ground issue in the aft??
Will measure as the Body maintenance manual instructs but wierd it works without the switch connected.
In progress: Suspected Relay problem
4. Horn works as hotwired to battery, ignition is OFF. Looks like it should be in the elec wire scheme. Anyone can confirm this?
This is the main elec items I've found. Hope to get some guidance or experience maybe by some of you.
Thanks!
(Excited to be a new HJ61 member)
Thanks!
