Door ajar light on instrument cluster 98-02?
Frisco, CO
Can someone confirm if there is a door ajar light that illuminates on the cluster?
The KSW (key unlock warning SW) circuit ties into the cluster, but the wiring diagram of the cluster doesn't show why.
Usually there is a symbol of some sort, ie; a light/LED, etc.
Thanks
Yes. It is towards the right when looking at the instrument cluster directly. Mine went out, so got it reaplaced no more than a month ago!
Mine is a 2000.
Mine is a 2000.
Was it just a bulb you had to replace or the key unlock switch?
Did you have any immobilizer or key issues when the light failed?
Thanks for the reply
I replaced just the dash bulb. It is about an inch left to the park brake light bulb on the instrument cluster.
Wait.. just went to check, looks like my key fob got a dead battery or something.
I typically use the key to lock and unlock. No issues with the immobilizer when the bulb was out. The interior roof door light works as usual reladless of the deadbulb
