Donor engine not firing.
flowood, ms
Replaced busted 3FE (head gasket) with running 3FE long block. All fluids, ground wires (3 each) and quick connect plugs reconnected. Engine tried to fire twice then nothing but turning over since. We are getting spark/fire to the distributor but nothing past the distributor. Any suggestions or advise would be appreciated.
Check fuses in cabin and the fusible link located near the battery
fusible links should be right off the positive terminal of the battery
