dome lights and sunroof not working! (1 Viewer)
Bellingham>Boulder
I posted in the 80 tech section but haven't gotten any ideas yet. I thought I'd ask you guys for some help. It's a 96 80 series. The fuse is fine. The sunroof is wide open. :doh: Thanks, Ryan.
You need to check all wiring, to know if to the SunRoof have apropiate 12V ( 24 if is you case ) and the motor, the controls and all thinks involved ...
Look in your manual there should be away to close the sunroof manually. I think it should have a crank or something. Then find the motor for the sunroof ,just look around up top there and follow the sliding mechanism you should be able to see it. Get a multimeter and see if you have power to the motorwhen the button is pushed? I don't know what else to suggest
Still thinking! You might have a relay under the dash after the fuse? Follow the wire and see where it goes. Check power before and after each component.
