Hi Im considering the C97-146VT and C97-147 VT for a tapered 2.5 inch lift I would like to know id this setup helps articulation and gives it a slinkier offroad experience. On road setup if its firm enough and what weight has been added.I run the 4" progressives -
the ride is awesome
the powder coat is falling off after 2 years (my old springs lost all the powder coat too)
Have this exact setup on one of our shop rigs. Haven't received the rear MRR shocks yet so we haven't had a chance to flog it, but the ride is nice so far. Has our bumpers front and rear, winch, 35" spare out the back.Hi Im considering the C97-146VT and C97-147 VT for a tapered 2.5 inch lift I would like to know id this setup helps articulation and gives it a slinkier offroad experience. On road setup if its firm enough and what weight has been added.
I'm planning on running 33 inch on a 4.56 Ring n Pinion with a low range crawl gear of 3.12
Delta,Have this exact setup on one of our shop rigs. Haven't received the rear MRR shocks yet so we haven't had a chance to flog it, but the ride is nice so far. Has our bumpers front and rear, winch, 35" spare out the back.
Looks like going to need to update the spreadsheet linked here: Compiling/comparing lift and caster data - https://forum.ih8mud.com/threads/compiling-comparing-lift-and-caster-data.1099600/ with new data, gotta go get it though. Measuring from hub to flare isn't really possible with this thing without taking the wheels off.Delta,
What were the fender to center hub measurements with this spring setup?
I have the exact same spring setup. I am 33" hub to fender on the rear and 33 1/4" on the front.Delta,
Wouldn't 33" hub to fender be like a 10" lift? Perhaps it's 23"I have the exact same spring setup. I am 33" hub to fender on the rear and 33 1/4" on the front.
The IMS shocks are out of control awesome compared to the OMEs they replaced.
Getting an alignment this week and will have exact numbers but the truck is feeling excellent on road with the 4" Delta VS arms.
Was going to say. 23-23.5 sounds more correct.Wouldn't 33" hub to fender be like a 10" lift? Perhaps it's 23"
Hahaha yes 23". Not ready to go that tall!Wouldn't 33" hub to fender be like a 10" lift? Perhaps it's 23"
the ride is awesome
Hey Delta VS, that seems like a fair amount of weight for the progressive coils. Are you happy with how it rides, or do you wish you had gone with a linear coil? How much weight do you have in the rear of your 80 that is running the progressive coils?Have this exact setup on one of our shop rigs. Haven't received the rear MRR shocks yet so we haven't had a chance to flog it, but the ride is nice so far. Has our bumpers front and rear, winch, 35" spare out the back.
To bet clear, there is a difference between the progressive and variable taper coils, keep that in mind. The ones on the Patrick's rig are the variable taper. Haven't had a chance to get axle weights for this one, so don't know actual weights. It sits nice and level with the spring combo though.Hey Delta VS, that seems like a fair amount of weight for the progressive coils. Are you happy with how it rides, or do you wish you had gone with a linear coil? How much weight do you have in the rear of your 80 that is running the progressive coils?
I am trying to decide between Dobinsons linear and progressive coils. I have a Slee front bumper and winch, and out back I have the stock bumper but have added a 53L frig, a 4X4 Labs interior rack holding two jerry cans of water, recovery gear, and camping kit. I don't carry much on the roof, maybe 100 lbs. top up there when it's a family trip. Do you have any thoughts about linear vs. progressive coils for my situation?
Hey Delta VS, can you post up the center of hub to bottom of fender/flare measurements at each of the four corners? I'm thinking about those same springs for my truck.Have this exact setup on one of our shop rigs. Haven't received the rear MRR shocks yet so we haven't had a chance to flog it, but the ride is nice so far. Has our bumpers front and rear, winch, 35" spare out the back.
