Update: I WAS able to pull the "center airbag sensor" WITHOUT removing the dash, steering wheel/column, AC, etc as stated in the factory service manual. I did have to pull out the stereo, air vents, top trim for center console and some misc odds and ends. This exposed the center airbag sensor. The front bolt (12mm) was easy to remove, the rear two were a different story. One was accessible from the side through a little access area by the passenger kick plate/leg padding/whatever area. The third one (driver's side closest to front firewall) was tough to access without a really long wrench. I picked up a set of HF ICON super long double box end reversible ratcheting metric wrenches....that made it a breeze to pull off the last bolt (had to pull computer module so it would make contact with the bolt during removal, otherwise ratcheting mechanism wouldn't ratchet). Similar sets sell on Amazon under the name Mountain 5-piece double box end ratcheting wrench set. I'd recommend the HF ones because even though the Mountain brand has a lifetime warranty, good luck actually getting it honored. After the third bolt was removed, had to pull the Yaw Rate Sensor to make enough room to detach the big yellow connector and pull out the airbag comp.
Airbag comp and seatbelts are currently on their way to SafetyRestore for refurb.
When they return, I WILL UPLOAD A VIDEO SHOWING THE ENTIRE PROCESS OF REMOVAL, REFURB AND RE-INSTALL.
Hopefully this will save someone in the future A LOT of hassle and headache....turned a 8-12 hour job + specialized equipment for AC removal/recharge into a 1-2 hour job with basic tools.
Getting that third, tough to access bolt back in upon reinstall will be a little tough, but I've got a few ideas to make it happen, and a worst-case-scenario backup plan that will definitely work if all else fails. Again, I'll upload a complete video when the job is done and the refurb'ed SRS comp is reinstalled.
Thanks again for the help everyone! Very much appreciated!
keywords airbag computer, airbag ecu, srs computer, airbag sensor, airbag controller, Land Cruiser 200 series, Land Cruiser 2008-2021, TLC, Toyota Land Cruiser
