- Thread starter
- #421
I swapped E and F wires (black and green) and it blows the 15A ENGINE fuse. So, I just unplugged it for now. But, it didn't blow the fuse when I had it setup, hmmmm.
New problem. EDIC Seems to be wired wrong too.
When I turn the key to "START" the edic opens.
When I let the key sit in the "RUN" position, the edic closes and shuts the motor off.
Hmm...
.....When I turn my key to "on". nothing happens with the edic.......
Pretty sure that this in itself indicates a fault.
I believe the IP lever should be moved to the "midpoint" as soon as the key is turned on.
I Just ran outside to check that very point on my truck, and the arm stays in the off position ( full forward) until I turn the key to start and then it goes to over inject ( full aft) and then centers and soon as I release the key.
When I turn my key to "on". nothing happens with the edic. It is full forward. ..
...When I crank it - it moves full backward (toward the firewall). So, after the motor is sputtering started (video after I sort this out), and release the key back to the RUN position - the EDIC moves fully forward and kills the fuel. ..Hm......
... I'm thinking oil pressure sending unit might be your culprit. No oil pressure tells the EDIC to go straight back to off. Sometimes after an oil change you don't get oil pressure fast enough and the EDIC shuts it off after about three seconds of running. It's a place to start looking
So my revised reply is
Yes. That's normal with the oil switch connected.
However, if you disconnect the oil switch (just pull the connector off) the lever should then get moved to the mid position by the EDIC motor. (And this is a useful check to perform right now.)
When i disconnect the oil connection (both the sending and pressure) the edic in the ON position still stays all the way forward (off), there are no changes.
... but I've got to get ready to leave for work soon.
