On the subject of your EDIC problem Dallas...
Earlier on I said this:
.....Did you replace the fuse you blew when testing your alternator Dallas? (Sorry ... I don't have wiring diagram in front of me so I don't know whether this is relevant or not anyway.)
Well looking at the diagram right now, a blown/faulty 15A engine fuse looks to me like it would indeed cause exactly your problem.
(And just so we don't lose sight of it .... I see your problem as being simply that ...
with your oil switch disconnected ... your EDIC motor won't put your IP-lever in the mid/run position when your key is in the "on" position.....And it SHOULD put your lever there regardless of whether your engine is running or not (provided your oil switch is disconnected).
#1: Oil sensor (tested as a good sensor) OFF/DISCONNECTED.... and the key springs back to "ON" the EDIC shoves the rod to "STOP"......
I'd call it an oil
switch ......but anyway ... here you're confirming once again the fault that I've typed in bold above.
Hey Dallas I've recreated you problem on my truck. You know that 15 amp blown fuse you have, change it . While trying to jumper wires to see what's doing what I blew that fuse and It's doing exactly what you're describing Starts rus for a second or two while the EDIC motor cycles to OFF. I bet your not getting glow plugs either. Try that out. .......
Here Bandit_guy is confirming what the wiring diagram suggests to me. That is, if no power is reaching your EDIC relay's IG terminal from your engine fuse, then your EDIC system will never know that you've turned your key to "on" (so it won't put your IP lever in the "run/mid" position.
However by associating the engine fuse with "glowing", he may have misled you. Yes - a blown fuse will stop the "glow momentary switch" (on the dash) from working but it won't stop your "turn key backwards glow operation". So you can still glow your plugs with your key when your engine fuse is blown.
NICE pictures - THANKS!! I did replace that fuse. I can glow the system, everything appears to be OK. ...
But did you use the key or the dash switch to glow your plugs Dallas. (In other words, are you SURE the IG terminal of your EDIC relay is getting 24V via your engine fuse.)
I suggest you recheck your engine fuse and check you are getting 24V to the IG terminal of your EDIC relay when your key is in the "on" position.
.... I'm digging into the EDIC motor here in a bit to see what I can find out internally.
But why? That's "going round in circles" Dallas. The non-invasive tests you did (following that post #55 in Theo's thread) confirmed it was A OK.
