I do have a port on the side of this carb that is "dead" at idle, but I haven't tested it further.
Doug, I did a lot of research here as well as on the net and 99% of the advice was to go straight to the intake manifold. I have not experienced any of the difficulties you pointed out. It quite simply has been one of the best things I have done to this old rig. I was unable to find a dwell meter or timing light down here and have both coming from the USA at the end of the month. If I see something untoward with regards to the timing I'll let you know.
1978 USA is the only year that is both vacuum advance & vac retard. There are 2 fittings on the vac can. The closest to distributor is retard, the one on the outer end of can is advance.Hate to hi-jack, but would a 1978 be vacumn or mechanical advance?
For US market:I have some questions for you guys since your posts started me thinking about all this. There are vacuum advance, and vacuum retard distributors, and I have never really spent any time thinking out the difference between the two.
Toyota used both advance and retard. Weren't the retard dissy's earlier, and the advance later? What year did Toyota make the change?
Yes. It would cause the engine to start, but as soon as it was running, the vac retard would pull 20 degrees of timing out, causing the engine to barely run.If you had a vacuum retard dissy and hooked the dissy vacuum to manifold vacuum, would this increase the retard of the timing at an idle?
