All right, I'm at wits end this evening so I need some mud assistance. Motor is a very fresh F, besides weber jetting, the motor runs awesome.
Currently the engine had a brand new 2F distributor, year unknown but it is a vac. retard model, small cap. So I thought a vac. advance distributor that I had would be better and went to install that. After installation, the engine would not run. I did not turn the engine between installation.
After an hour, I said screw it, and reinstalled the 2F distributor. Now I can start the engine, but it will not run without throttle. If you advance the crap out of the thing, you can get it to idle at as low as an F engine will idle (200rpm, maybe at most?). However, it is completely undriveable now.
This is what I did:
1. bump truck backwards until at the TDC mark on the flywheel
2. pull off the valve cover and make sure the first two valves have a little wiggle (assuming this is the compression stroke TDC)
3. Point oil pump slot towards cyl. 4.
4. Postition distributor and install so rotor points just a little to the left of cyl 4, or #1 on the distributor cap.
So what could I have done wrong? I obviously messed something up, but I now have no clue what. The timing is wayyyy off, or at least it runs that way. I'd would love any and all suggestions so I can get this thing to Pismo shortly.
Is it possible that I am just installing it 180 degrees off, over and over? Would that even run. What else could I have possibly done.
Thanks,
Jesse
This is what I did:
Thanks,
Jesse
