Hi all -
I've read /u/linuxgod's most-excellent thread on his 200-series setup for towing a travel trailer, and I'm hoping for some extra feedback from anyone who has had experience towing on mild- to moderately-difficult offroad situations.
Where I live, there are lots of fun places to camp that are at the end of a Forestry Service Road (FSR), some of which are maintained better than others.
My current goal is to buy an LX570 (the most common version where I live in Soviet Canuckistan) then buy and/or build out a smallish trailer somewhere in the 3500 lb. wet range (well below the 7000+ lb. rating of the 200) that is sturdy enough to survive the kind of washerboards and bumpy roads I expect to drive on.
I have no doubts about the trailer nor the LC's abilities to handle the FSRs on their own - my question is about the towing combination when the road gets rough, and in particular how I can help the transmission from cooking itself.
By "rough roads", I will sometimes encounter places where the road can be a pretty severe grade (12% or greater) with uneven/gravel/smallStone surface for an extended distance (1/2 mile or more). I'm more than happy to air down and pick a speed and a gear to take these stretches slow and careful, but I'm curious how much control the driver has about things like locking the torque converter to prevent overheating.
For instance, if I select a combination like second gear in low range, would the transmission start in first, shift to second, then lock up the converter? Or is is speed dependent? Or ???
(I have seen OBD2 apps that can at least display tranny fluid and torque converter temperatures and similar, but that's only part of the solution. I've also seen torque converter override/lockup electronics packages from third party towing equipment vendors which leads me to believe that the transmission might sometimes need a bit of extra guidance in order to do the right thing.)
So does anyone on here have any experience towing with their LC200/LX570 offroad that could chime in with suggestions or advice?
And can anyone explain the nuances of how/when the torque converter locks up in these vehicles, is it dependent upon Hi/Lo range selection of the transfer case, gear selection, speed, etc.?
Much thanks in advance.
