I put in a disc brake system out of a 77 fj55 into a 77 FJ40. I cannot lock up the disc brakes. I used my 72 stock master Cylinder and booster with the residual valve removed and a proportioning valve on the rear line.. I did a rebuild on the M/C, bench bled the M/C and bled and rebled the system and the problem persists. The rear brakes are working fine. Any ideas? Is there any stock toyota M/C tht will work with my 72 booster? Any suggestions on what else I might try or am missing?
