1972 FJ40- So I have a dim left taillight/blinker. Right side is bright and works well.
New Tailightails both sides.
I have run a long ground from the ground bullit connector directly to the negative terminal of the battery. No luck. Then I hooked up the ground built connect to where is suppose to be at the back of the truck and then used the long wire to connect to the power side of the taillight directly to the battery and it’s brighter.
Also on the left light, with the taillights(marker lights/parking) on and the blinker on, only the one filament lights up and blinks. The right side taillight the marker filament stays on and the directional filament blinks.
I really don’t want to open up the harness to try and find a crush/ poor power wire. Should I just run a new wire and splice it in just before the connector on the firewall?
Is this the connector I’m looking for the the rear lights/blinkers?
Thanks
Steve
Thanks
Steve
