For Sale Dillon, MT. FJ62 Engine, transmission and transfer case.
Dillon, MT
3fe engine, transmission, and transfer case from 1989 FJ62. 200,000 miles. It ran and shifted fine when I took it out. Just wanted something else. The vacuum actuator on the transfer case did break while being taken out.
$1,250.00
Hi,
do you have the engine wiringharness, ecu and airflowmeter for sale of this engine.
Thanks
Yes, I have all that with the engine. The wiring harness is not fully intact but should all be there. Radiator is also with it. I can get compression numbers as well when I get back home in a few days.
I would be interested in compression numbers. Also any detail you could provide on the aspects of the harness that are not in tact (how many cuts, or missing/broken connectors)
Thank you
pm sent on T-case
Were you able to get compression numbers? Also, your CL ad states 175k miles. Do you know whether it's 175k or 200k?
If Matt takes the tcase, I may be interested in just the engine only or engine/trans.
@toywyo is this sold?
I sent a message last week and the craigslist ad is gone
