Hey All,
I opened up my rear differential to investigate some lateral play I was having with my axles (excessive in/out play with each wheel). On inspection, I could visually see a bit of play between the axle ends and the spacer block and a feeler gauge revealed my clearance was a bit excessive at .78 mm compared to .04-.46mm specified in the FSM. Next step was to pull the spacer block to see if there was wear and to potentially order the next size up.
Here's where I come to the issue. On removing the differential shaft pin (see #12 in pic), I learned the bolt had been snapped off by the PO and all that remained was about a half inch of bolt. I've never seen a bolt snap off mid way in a hole, but I was able to use a mirror to view into the hole and it does appear this is the case, though it is hard to tell. So here are my questions:
- Has anyone seen this before?
- What are my options to remove the broken bolt assuming I can't get a straight shot to drill it out (again it's a half inch into the hole and the pumpkin blocks access). Do machine shops or other places like this have special drills/extractors for this type of thing?
- If I'm not able to remove the shaft pin, is there any way to remove the axles, to make the repair or replace the entire 3rd member? If not, am I looking at a new axle short of being able to cut out the spacer with a saw or other?
If it comes down to a new axle, I suppose I'll just put it back together and drive it until a good used one comes along at the right price.
thanks for all your help.
Brian
Brian
