Diff breather extension - question?
Prescott Valley, AZ
I just added the J-spring, L-shock lift to my 97 LX.
I've seen some posts where people just add new longer length hoses...
Since it appears to just be fuel line, or replaceable with fuel line - would it work just to add a little inside connector and then another few inches of hose?
Sure, you can easily splice it with a barbed brass fitting and a couple of hose clamps. The diff. breather mod write-up has a couple of spots where there is a three way tee splicing two lines into one as they're collected and extended into the engine bay.
:beer:
Rookie2
12 extra inches of hose might be cheaper than the hose coupler. Just replace the entire legth, and that crappy flapper valve.
There are 2 issues with the factory diff breathers.
1. The flapper valve creates a vacuum which can potentially allow water to be sucked into the diff housing through the hubs. Frankly, I see this as a minor issue but it was one of the first things I "fixed" because it was well documented and easy to do. The vacuum also pulls birf grease past the oil seals into the diff housing.
2. The factory locations for the ends of the breathers is too low for most water crossings. To "fix" this requires a longer hose than you are suggesting. I see this as the bigger issue; especially if you do any water crossings more than about 10" deep.
-B-
Are you saying replace the flapper valve box on the front hose, i.e., throw it away and just use longer hose?
flapper valve box?
My 93's flapper valve was about the size and shape of a pencil eraser, and did not function as designed. Easily replaced with a 'crank case vent' style filter from Oreily's. Extended into the engine bay.
Ahh, that seems simple enough. I will have to follow the lines to see the whole current setup.
I did forget to attach the front breather hose to the fitting on the axle the other day, and drove maybe 20 miles. This morning there was maybe 10 drips of fluid which came from the open breather.
My question now then...if the fluid can come out from pressure (I assume) - what would keep it from coming out of a "crank case vent" which is just a tiny air filter?
Is the hose length what keeps the fluid from having enough pressure to come out the top?
Doc said:
flapper valve box?
My '95 has a little box that the hose plugs into that is connected to the frame, and then vents through the top of that box.
Yes, aided by a higher location like in the engine bay. Have you read this thread?
-B-
The rear breather should look like this before modification.
The 80 series rear diff breather valve after modification is shown below;
-B-
Say, I see how the tranny diff breather feeds into the tranny dip stick, but what does it do there? Does it "breath" thru the end of the tranny dip stick? If I extend these lines, do I need to cap off where it fed into the tranny dipstick?
-B-
Interesting...first time I had come across this. What are the benefits of connecting all of the breathers together beyond raising them all into the engine bay? Seems it would be easy to just use an extended hose on the two diffs and be done with it? Or are the tranny/case breathers vulnerable as well?
I feel the tranny & Xfer breathers are OK at the top of the tranny fill tube. At that location they are maybe 3" below the inner fender location shown in George's pics. There are no other benefits to relocating them (tranny & xfer.) Someday I may add another couple of tees and take them all up to the single location but my water crossings are few and far between since most of my off-road trips are in New Mexico and surrounding areas.
-B-
It's just a bracket/mounting point above the tranny and transfer for the ends of those lines to live. It does not penetrate into the tranny dipstick tube.
:beer:
Rookie2
I don't see much water either in Colorado wheeling (used to have a 3' crossing, but those trails were destroyed in the Hayman arson).
I was looking to extend my front diff breather and ran into this thing. What is it? The breather hose connects into the bottom and it has a port on the top, and it is attached to the inside of the frame.
That's the breather "black box" that others have mentioned. I pitched it and used the rear brass breather valve as depicted and modded and mounted in the engine bay. Both breather lines run to the one breather valve.
-B-
Are you referring to the "teller county car wash''? On the Hackett gulch trail. I loved wheeling and dirtbiking out there when I lived there. Now I'm stuck in NH with a lot of stupid mud! So extending the breathers is necessary for me. Do they really need a filter on the end? I was thinking about just running them to the air box and putting a bulkhead hose barb on it. Tie em all together and terminate it there. But do they really need anything on them?
As long as they are getting clean air and not throwing axle pollution into the intake you shouldn't have a problem.
Erratic,
Look at the dust and grit that settle in your engine bay. Want some of that in your differentials? Didn't think so. A pop on fuel filter for a lawnmower is about $1.50 and cheap insurance at that.
DougM
