So I am making plans for my project 40 and I have decided to go diesel rather than use the 2FE I built and I am having difficulty deciding what motor to choose.
Current thinking is Isuzu 4BDT1/2, Merc OM617 5 cyl, or 1HZ. I have considered other diesels from the above as well, and am still open to ideas though I think the 4BT has rattled itself out of the picture.
I have an H55F to put behind whatever I choose and have the ability and means to make a bellhousing adapter.
Pros and cons -
Merc - cheap donors and lots of them. Rebuilds are pricey, but i hear you can treat the engines as disposable - engine dies, go find another with lower miles. Motors are short, compact and relatively light.
Isuzu - more expense in getting motor/donor vehicle. Rebuild kits are easier to get and cheaper to do. Heavy, tall, but short lengthwise.
Toyota - well, it would be a Toyota, which I would love to do regardless. But, it seems just getting one costs more than the Merc and Isuzu motors and rebuilds combined. Doing a swap would best be done with a half cut.
I am planning on putting a 40 body on an 80 frame, so the Toyota option is appealing as a semi-drop in. But I am concerned about costs...
I'd like to get 180 - 200 hp and 250+ ft-lbs without blowing up the motor, and I'd like to be in the 20-22 mpg range if I can. Bigger turbos are fine, I just want to make sure I won't push too far and need an early rebuild.
So, any thoughts? I have read myself cross eyed on numerous thread on all three candidates. I can see solid reasons to go with all three candidates. I'd hate to leave this to the $$ to decide ...
Pros and cons -
