Diesel Compression Tester (2 Viewers)
I would like to test the compression on my 1985 3B, nothing wrong, just curious. I would like to buy a quality gauge, but I realistically probably will not use it 10 times in my life, so it is hard to justify spending a lot on one. I generally don't like to trust Harbor Freight for these kinds of things.
Can anyone recommend a decent tester?
What about an adapter? I have searched and it looks like an adapter that is 10mmx1.25 by 28mm, is that correct? Can anybody recommend a brand?
If you're only using it a few times just pick up one of the inexpensive compression tester kits on Ebay. They will have an assortment of adapters, one is almost always the 10mm x 1.25. Just ask the seller before bidding to be sure. They are usually Harbor-freight like in quality. I have one of these cheap sets and also a MightyVac digital compression tester. They both provide the same results. The MightyVac is nice because it will remember up to 12 cylinders worth of compression results. So I can do three passes on a 3B and not have to write anything down.
You might be able to find a Kent Moore brand tester on Ebay. That's what was used in most GM service shops for years.
I bought a cheap kit off ebay recently.. I used it to test the compression on my old 2H prior to removal.. it worked ok for that.. but the release valve didnt work.. no biggie..
I installed my new engine then tested the compression.. the gauge blew out on the second cylinder.. the 8th cylinder I tested with the kit.. <sigh>
This is the cheapie I bought that blew up:
http://www.ebay.com.au/itm/20-pc-Di...36?pt=LH_DefaultDomain_15&hash=item35db3e2dc0
It's hard to know if that adapter will work with the tester. The quick-change fittings aren't universal and using the zoom feature on those images looks like the connections are different. You would be better off with a Kent Moore kit that includes the adapters.
A couple of photos to demonstrate the connection points that look to be incompatible. But the Kent Moore unit comes with an adapter that might make it work. Hard to know.
