Diagnosing a Wind Whistle (1 Viewer)
Tank5
When I get my 45 up to speed I get annoying whistle. I have new door gaskets / weather strip on both sides and stacked new roof and upper windshield frame to roof gasket. It is hard to tell where the whistle is coming from. I can feel a significant breeze coming through between the roof panel and the support brace that rests on the windshield frame. I suspect this gap could be where the whistle is coming through.
You can see in the picture that the gap at the corner is bigger. What is the appropriate way to seal this? What have you done or seen done?
I have used this with good results, its not permanent, and comes off easy!
Is this tacky or just a soft foam you stuff into the crack? Either way I will order some up and give it a try. Thanks!
Start with painters tape to isolate the whistle. Btdt. Glass half full moment. Your annoyed by a whistle at speed, which means your driving it. Better than most in the forum.
