SOLD Denver, CO 1994 Cruiser CLEAN (1 Viewer)
Lakewood, CO
Year
1994
  1. 80 Series
80513 Berthoud Colorado, United States
Mileage
236600
1994 Toyota Land Cruiser
NO LOCKERS
Selling another one of my many Cruisers that I have had the pleasure of owning and restoring.
-Rust Free
-No accidents
-No bodywork
-236k oroginal miles
- Headgasket replaced by L1 Automotive (Specialty Toyota Shop) with OEM parts and new valve seals
- Upper oil pan, lower oil pan, and pan arch resealed by L1 Automotive
-New oil pump seal and stainless screws OEM
-New front main seal OEM
-New oil level sensor oring OEM
-New speed sensor oring OEM
-New fusible link OEM (trail spare included)
-New remanufactured alternator (trail spare included)
-New drive belts OEM (trail spare included)
-Front and rear diff serviced with new 100 series magnetic drain and fill plugs and crush washers
-Transfer case serviced with new 100 series magnetic drain and fill plugs and aluminum washers
-Transmission flush with 16 quarts of Valvoline Max Life full synthetic ATF
-Powersteering flushed with Valvoline Max Life full synthetic ATF fluid
-New Koyo radiator
-New thermostat and gasket OEM
-Coolant flushed with Thermocure
-New coolant with 50/50 mix with distilled water
-New power antenna OEM
-New Fender flare gaskets and hardware OEM
-New belt line moldings OEM
-New bumper stainless steel trim OEM
-Front bumper sandblasted and powdercoated
-Side bumpers repainted
-New windshield with OEM windshield gasket
-New wipers front and back
-New air filter
-Tow hooks sandblasted and painted with enamel paint
-Wheels sandblasted and powder coated
-New Hankook 35" Dynapro MT tires (35" trail spare included)
-New OME 3" lift with heavy duty front and rear springs
-New OME shocks
-New steering stabilizer
-Paint does have some fade, but has been polished
Interior was completely removed along with the carpet and power washed. The carpet is very soft and most importantly has no residue from any soaps or cleaners over its 26 years. The metal floor was cleaned and disinfected with Lysol and every nook and cranny was blown out with compressed air - interior is CLEAN!
Truck is very clean and has been serviced the right way. I'm a firm believer in Toyota OEM parts and torque specs. No half-assed jobs or hacking on this truck. Every nut and bolt I touch is cleaned and put back together with anti seize. This truck is ready to go and can be driven across the country as it sits.
Asking $14900
Brian 4024306337
hadacol
NC
interested in trade? for locked and lifted ‘95 80, has arb front/wench, well maintained and HG done. rust in usual east coast places but manageable. PM is open
Lakewood, CO
AC works great and so does the heat. Everything works as it should. Everything from the 'D' light to the power antenna!
