you bet, let me know when you want to borrow my 200 for a couple weeks to design a rack for that modelWow, thanks for the great write up! I’m sure others will find it quite helpful.
If i put my RTT on this one I think i'll just move the two load bars to wherever I want to bolt down the RTT. Should be easy. Front will be easy access through the sunroof, rear I'll have to position the load bar such that I can access through the side with an open end.I really like this rack setup. For people that are running RTT, how are you mounting them? I have an Alucab 3.1 RTT that I ran on the 200 on a Gamiviti rack. I put an old style ARB rack on the 80 but it sticks up high and I don't think it'd make an ideal base for the RTT. With the Gamiviti, I mounted the Alucab crosssbars to the round tubes along the sides, but that requires access underneath to put the nuts on. I don't know how I'd do it with this rack. I store the tent suspended in the garage, so I can put it on and take it off pretty quickly (electric winch).
grab handles would be cool. I'd like some camp lighting on the sides and some chase lights. Probably will fabricate my own brackets, but yeah would be cool if there were more available already.I love this rack. I’m waiting to see if more accessories become available soon like plug and play grab handles, stuff like that.
The nice thing about aluminum is you can just drill through wherever you want to mount stuff. Here's one approach to chase lights.grab handles will be cool. I'd like some camp lighting on the sides and some chase lights. Probably will fabricate my own brackets, but yeah would be cool if there were more available already.
Trying out a couple different approaches to side/camp lights. The S1 lights just bolt into one of the existing holes, the rock lights need a small bracket that mounts to the existing holes.grab handles will be cool. I'd like some camp lighting on the sides and some chase lights. Probably will fabricate my own brackets, but yeah would be cool if there were more available already.
Ooh, i like this rock light idea. Won't even notice them on there they way those are mounted. Any idea how well the light projects in that position?Trying out a couple different approaches to side/camp lights. The S1 lights just bolt into one of the existing holes, the rock lights need a small bracket that mounts to the existing holes.
View attachment 3863141View attachment 3863142View attachment 3863143View attachment 3863144
Yes, need to make a video of these. Need to get the Cummins rig off the lift in order to do so.Ooh, i like this rock light idea. Won't even notice them on there they way those are mounted. Any idea how well the light projects in that position?
I was wondering about a Rigid 6" light bar (just because they are just taller than an inch vs Baja Designs being around 2") mounted on a bracket so they poke out a tad from one of the side openings - then their angle can be adjusted. But maybe that rock light or the S1 angle would do just as well.
I've got a couple of those rock lights unmounted. I'll temp wire them up and see how it is. Is that bracket something you guys are making? prob easy enough to fab something up that simple.Yes, need to make a video of these. Need to get the Cummins rig off the lift in order to do so.
yes, have the file for those parts, once get a chance to test both sides out and get a video, that's when I was planning to make a decision on what to offer.I've got a couple of those rock lights unmounted. I'll temp wire them up and see how it is. Is that bracket something you guys are making? prob easy enough to fab something up that simple.
Cool, I'll keep an eye out. How are you passing wiring through the roof? Or are you going down the outside of the A Pillar tucked behind a snorkel like some do?yes, have the file for those parts, once get a chance to test both sides out and get a video, that's when I was planning to make a decision on what to offer.
Some go down a-pillar and some go down around the back inside the rear hatch jamb, then in through grommet below QPM.Cool, I'll keep an eye out. How are you passing wiring through the roof? Or are you going down the outside of the A Pillar tucked behind a snorkel like some do?
Would running PPF on the area of the roof the front of the rack rests on be an option? Protect the paint and keep things quiet with no gap? Just a thoughtWe just installed this rack to a customers 80-series build we are doing.
Obviously we had it pc’ed black. Rack goes together pretty easy and is light weight. However, for us there is one noticeable problem. After fitting the rack we drove this Cruiser over to Deltas shop and visited with them about the main issue.
The issue is the rack is designed to rest on the roof in front. Maybe that’s fine on a 30yr old paint job with clear coat fail but that’s not fine on this Cruiser which just got a complete disassembly paint job that cost $$$$$. We have mounted the rack far forward so it doesn’t contact the roof but to us it looks funny this way.
So we are going to need to take the edge back on the front piece that sits on the roof so there is a small gap between roof and rack. Delta explained why they designed it this way, for noise, and that’s fine but we can’t have a RR rubbing on this paint job. Delta did offer to work with us on a remedy and that’s fine too. Not sure at the moment if that will be our solution but again no way we are going to have the rack rubbing the paint bad enough to cause damage to the roof after a full body off (rotisserie) glass out repaint.
Cheers
Maybe get some heavy paint protection film and run with it - I’d do that before creating a noisy gap.We just installed this rack to a customers 80-series build we are doing.
Cheers
Maybe re-read my post there - I didn’t tell you to trash the paint. I think I said get some paint protection film to protect it, then enjoy the cruiser. Enjoying a cruiser doesn’t mean trashing the paint. If increasing the gap is the solution you want and have experience with it working for you, seems like a good solution you’ll be happy with.My personal 80 has a Bowfin with adjustable front panel. When I first installed it I gave it an 1/8” gap at most to keep wind noise down. It got some small rocks stuck up in that gap when I ran 100 miles through the desert at 60mph. So I raised the front panel to provide at 3/8’s-1/2” gap and next two trips on the same roads no small rocks stuck in the small gap.
Increasing the gap of this panel on my Bowfin did zero to increase sunroof noise. Up to 85mph.
So you are telling us to trash an absolutely perfect paint job that cost more than most Cruisers to avoid some noise?
Cheers
