Definitive list of AHC maintenance items (5 Viewers)
Indro,
Grateful for the note back.
-At N, my hub to fender is exactly the same at all corners = 22" ( My wheels poke, so actual number is less)
-I have a Prinsu roofrack and a wooden drawer system made by the previous owner. However, my spare tire is currently off as I'm replacing the rusted hoist system.
-Truck settles well into L, 17 seconds. L -> N, 35 seconds. N -> H, 40 seconds. I gain about an 1" - 1.25" at each move.
-In H, I'm 23.25" in the front, level. And 23.75" in the rear, level.
... Installed and adjusted the sensor to the highest level. Techstream is showing rear pressure at 5.6, which is good, but showing the RR heigh control sensor at -.05. I can't make any additional adjustments to the sensor and its brand new. Why would it be at -.05? My rear shocks are old, is it possible that they're not able to raise the rear the correct amount to match the sensor reading?
Can't see the problem. 0.05" equals ~ zero, which is the only aim of the height control. When the ahc adjusts the height to N, it will just increase or lower the pressure until the height sensor reads zero, and 0.05 is close enough. It will always be zero in N height, whatever your actual, physical height is, as long as pressures and mechanical boundaries are within operational limits. What is the problem?
uHu, that's on me, it's -.5
and I can't adjust it further up. New springs, spacers, fluid/accumilators, and new Oem sensor. Just don't get it.
Bonjour,
Est-il possible de remplacer les ressorts de suspension AHC 48231-6A750 (hauteur 455 mm) par des ressorts AHC 48231-6A770 (485 mm) ?
Merci
Marc74
uHu, c'est de ma faute, c'est -0,5
et je ne peux pas le régler plus haut. Nouveaux ressorts, entretoises, liquide/accumulateurs et nouveau capteur OEM. Je ne comprends tout simplement pas.
Bonjour,
Merci
Marc74
Bonjour,
Merci
Marc74
Bonjour,
Merci
Marc74
ce serait possible, mais cela nécessitera probablement un recalibrage du capteur de hauteur arrière.
Bonjour,
Merci
Marc74
Bonjour,
Merci
Marc74
Merci ! Sera-t-il possible d'avoir la confirmation de quelqu'un qui a remplacer les ressorts AHC 48231-6A750 par des ressorts AHC 48231-6A770 et du ressenti .
