- Thread starter
- #21
The EGR valve can still "test to spec" yet continue to create a stumble every time it opens. Just to rule it out, pull the vac hose leading to the EGR valve & plug the hose. Drive the truck around the block. See if that fixed the stumble.
Just back from a good test run with the indicated hose plugged. No noticeable change.
Here is a bit more data: I just bought a vacuum gauge and it reads about 10 inches at idle coming off of the gas filter thing. Will pop up to 13-14 after revving and letting off.
Also, I think something may be funky with ignition timing. The last time I set the timing, my timing light crapped out so I did the old school approach of getting it in range, going for a drive and listening for a ping. I advanced timing until I got a ping under load, then backed off until the ping went away. Well, I just got a working timing light and it is WAY advanced. I'd guess at least 15-20 BTDC because the mark isn't in view in the window. I tried setting it back to 7 BTDC and it ran like crap, stumble was worse, no power.
