I'm trying to diagnose a very elusive mid-range stumble and am checking out the fuel cut stuff. The FSM is vague, to me, about how to test. It says to check for continuity between switch and body with the engine off and on, but it isn't clear (to me) as to the "correct" result. I think, from the pictures, that there should be continuity (a complete circuit) when the engine is off, but the circuit should be open when the engine is running. Right?
I get a closed circuit in both cases, so I'm assuming that indicates a broken switch, right? Anyone have source for a replacement?
