i just bought 2004 GX470, and had it thoroughly checked before purchase just so I would know what needed fixing. Rear Airbags wasn’t one of them. Took it to the dealer to get recall done, and have them do their full maintenance inspection while it was there. He doesn’t find anything wrong except one of the rear bags is collapsed, I think he said. I remarked that when I was at stop lights I could hear the compressor going and adjusting the bags and I was wondering if that was normal. He said that wasn’t it, but that the issue with it would make the car drive more “bumpy” and might not be safe at times. I was kinda confused, so I asked him about it again, he said that it doesn’t drive like a gx470 suspension normally drives.
So my question is how do I tell if the bags are bad or not. They definitely deflate when I turn it off and Re-inflate when I start it back up and if someone gets in he car, it will kick back on to adjust. Then every once in a while I’ll hear it kick on at a stop light. When the car is running it sits level and normally, there’s no lean and for me it drives smooth and will change stiffness when I change the comfort level settings. Not that I mind if I have to replace, I was planning on it at some point with springs, but this is a little sooner than I had expected or am ready for (but hey, that’s what usually happens, right?).
Also, an oddity but not unexpected, they didn’t find the $4000 worth of issues my prepurchase inspection guy found! I even had to tell them about a leaky rubber hose at the lower drivers side under the radiator and they still haven’t found that. Is that the transmission cooler hose? Just about 6” long and 1/4” diameter that attaches between two hard lines. Looks easy to fix, just cracked and leaking...and they missed the obviously leaking drivers side axle seal. No biggie to me but I found it interesting
