- Thread starter
- #41
Link
Link
Does anyone know what code 44 is? Or where I can find this information?To read the codes before resetting the ECU - jumper the same two pins, 13 and 4 and turn the key on. The “off” light for the suspension height control will begin blinking. If there are no codes it will blink continuously every 0.25sec. When there is a code present it will blink a series of times, then pause for a half second and blink another series of times. Then it will pause for a longer period of time before beginning the sequence again.
count how many times it lit up before the first pause and write down the number, it should be between 1-8 if I remember correctly, 1-9 if I didn’t. Then do the same for the next sequence after the half second pause, again 1-8. For mine I wrote don a 4 then a 1 which is code 41. Now a longer pause happens and the sequence will begin again. If there is another code stored you will get a second set of numbers, mine was 51.
I think if you get a 13 or 14 it’s the height sensors. Mine were related to an open or short on the air suspension relay, 41 (probably when I took it out and turned the key on) and a continuously running compressor, 51 (probably from the leak in the air shock)
Thank you! Any idea how I would fix this? I haven't tried unplugging the battery to reset it yet...maybe that could help?Tank solenoid valve circuit
regarding tool to remove airline.. ive heard from the grapevine that the plastic locking piece actually serves as a tool... all you got to do is rotate it 90 degrees and reinsert and the locking buts will unlock.
I'm here only to say that the tip about connecting pins on the OBD2 port was what finally woke up my compressor on my 03GX after I replaced the airbags after visit in a local shop. After 245k miles and unfortunate visit on the lift for transfer case replacement the bags gave up. I bought cheapest thing available on amazon for $81 for two airbags and installed them. Spent another 30 minutes to find a way to pump them.It’s fixed! I got the repair guide and was able to read the codes and then reset it. Resetting it allowed the compressor to work correctly again.
To reset the air suspension ecu do this:
Make a jumper wire and jumper the DLC3 connector pin 13 to pin 4. Turn key to on, pump brake 8 times quickly. Turn off key and remove jumper.
Locate pin 1: lower right corner is #1
Counting right to left staying on bottom row count to pin 4 Edit: jump to upper right corner to find pin 9 then staying on top row count to the left until you get to pin 13. Put a jumper wire between those two pins and leave it there. Now turn the key to on (don’t start the car). To reset just push the brake pedal down and release it, 8 times in 5 seconds. The dummy warning lights will begin flashing at a regular interval. At this point turn the key to off and remove the jumper wire. Now your air suspension ecu is reset.
